Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
677 Perguntas Visualizar todos
Why is my vibration making a buzzing sound?
I have replace the vibration motor and that didn’t fix it I tightened it so hard it was hard to take out again and that didn’t fix it. I’m running out of ideas. When I try to move the motor when it’s nailed down it does not move yet it still makes the buzzing sound. I need help desperately. Fairly new to fixing phones would appreciate some help with this.
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I’ve had difficulties with the 8 and 8+ Taptic Engine’s making bad noises. What happens is the actual post the screw mounts into breaks of from drops and impacts. The trip the worked for me was glueing down the screw hole and then tightening the screw. Hopefully this helps.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Yair Gomez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 58
