Moisture damage on screen
Hello!
My iPad was in a bag where some soap was leaking, and my iPad was exposed for moisture damage of the soap. Here’s what it looks like, anything I can do?`All help appreciated!
Esta é uma boa pergunta?
Hello!
It seems the iPad itself is still working but you will probably have to replace the LCD panel and the digitizer glass. IPads are not particularly easy to work on but if you have good will and patience it can be done. Once you open up the iPad, the earlier the better, you will have to closely inspect it and remove any trace of liquid/soap with a soft toothbrush and some >90% IPA. Here’s a guide to help you getting an idea of the work you’d have to do:
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 157
