Ir para o conteúdo principal
MITSUBISHI WD-73C9 rear projection dlp HDTV
25 Perguntas Visualizar todos
Replaced Lamp TV shuts down still?
I’m having a problem with my Mitsubishi Lamp replacement, I did a replacement for the Lamp and it went completely smooth nothing broken just the lamp. I did a hard reset and when the tv turns on it stays on for about 30-40 seconds and then shuts down. The Tv also provides me with the 34 error code that the Lamp is bad but I had just replaced it, not also did I replaced it but I cleaned out the dust using an air can and is as clean as could be. Very confused, any ideas??
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
I have this problem and I see nobody answered you in 2 yrs. Did you ever find the answer?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Luis Esquivel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 22
