Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
604 Perguntas Visualizar todos
Can NOT turn on and charging light stays amber
Hey, I cant turn on my MacBook air after probebly running out of power.
No Sound, light or any sign of action other then the amber light on the charger.
resetting the smc turns charger light to green and back to amber.
Letting it charge over Night still amber. Disconnecting battery and pluging in charger does NOT change the amber light to green and still no action.
Hope somebody Can help me
Kind regards Michael
Esta pergunta é pertinente?
Pontuação 2
Adicionar um comentário
1 Resposta
Solução escolhida
With the battery disconnected are you able to start the system with just plugging in the MagSafe charger? The system should spontaneously boot.
If it does you'll need a new battery MacBook Air 13" Early 2015 Battery Replacement
Update (07/09/2019)
At this point I suspect your logic board has a problem. You’ll need to find someone local to fix it or you could just replace it MacBook Air 13" Early 2015 Logic Board Replacement has the logic board info inside.
Imagem de MacBook Air 13" Early 2015 Logic Board
Guia
Nível de dificuldade:
Moderada
1 - 2 hours
Imagem de MacBook Air 13" Early 2015 Battery
Guia
Moderada
15 minutes
Esta resposta foi útil?
Pontuação 1
3 comentários:
Hey Dan, Thank you for your quick answer.
No, when I disconnect the battery and plug in the MacSafe charger, nothing happens and the charger light is still amber instead of green.
por
@danj I had the same problem and your answer allowed me to troubleshoot my problem. Luckily it's just the battery. Sorry Michael that you had a logic board problem. Thank you, Dan!
por
@evanga2so - Thats great!
por
Adicionar a sua resposta
Michael Klostergaard será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 303
