Ir para o conteúdo principal
The Lenovo IdeaPad Flex 4-1470 Model Name: 80SA , manufactured in 2016, features a 14 inch touch screen display which folds around 360 degrees to be used like a tablet.
9 Perguntas Visualizar todos
Operation system doesn't start..
I tried to see bios screen to choose boot up device then I stuck on repair mode. None of the options are working. I was gonna replace hdd to ssd but now it doesn’t even start. Do you have a solution ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Once you replaced HDD with SSD , you have to install operating system to the SSD.
Watch this: https://youtu.be/THPikFuftdQ
Esta resposta foi útil?
Pontuação 0
1 comentário:
Mine has no usb or any other boot options and it doesn't see the ssd bootable even you set it up as bootable ssd
por
Adicionar a sua resposta
Serkan SARICA será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 168
