Ir para o conteúdo principal
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
128 Perguntas Visualizar todos
Ipad won't boot up. Apple logo flashing/bootloop. All help is welcome!
Hi guys!
The ipad pro 12.9”(1st gen) It wasn’t used for over a year. When booting it up after that period, the apple logo appears and disappears a couple seconds after it. This goes on and on. But it will only work when the ipad is charging.
What I tried:
  • Charged for 45min on charger
  • Hard reset, with no luck.
  • Putting the ipad in recovery mode, the itunes logo appears, stays on, but when I want to connect it to the pc it instantly shuts of the display. Pc can’t charge the ipad.
Might this be a battery problem? That the battery can’t hold it’s charge when charging. So the battery is ‘empty’. And there is not enough power to boot it up when connected to the charger?
Thanks in advance!
Nick
Esta pergunta é pertinente?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
It certainly appears to be a battery problem. Try keeping the iPad on the charger for 24 hours to see if this helps or not. If you do get the device to boot up, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery. Anything less than 70% of design capacity will require replacement. If the battery is in good condition, you can use a USB Ammeter to determine if the phone is really drawing current when it says it's charging.
Esta resposta foi útil?
Pontuação 3
I have this exact same problem. How did you fix it?
Pontuação 0
1 dos comentários:
Not, sold it for parts. My guess was that the motherboard was defect.
por
Adicionar a sua resposta
Nick Schulpen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 32
Duração total: 7,785
