Ir para o conteúdo principal
Why AOL email is not working on iPhone
Why AOL Email is not working on iphone? It works on my desktop but I am unable to add account on iphone.
Esta pergunta é pertinente?
Pontuação 2
Comentários:
I had to add the Yahoo app to enable AOL to work
por
Adicionar um comentário
8 respostas
Pergunta Mais Útil
What exact problem are you facing? Is it that you’re unable to login AOL email on iPhone or AOL mail not showing on iPhone or unable to send or receive the email on iPhone?
you can try these workaround to fix AOL not working on iPhone.
1 turn on and off airplane mode
2 reset network settings
3 readd AOL account
you can check more on how to fix aol email not working on iPhone
Esta resposta foi útil?
Pontuação 1
Comentários:
Good solution.
por
If your AOL Email is not working on iPhone then you need to reset your password
Here are the steps to rest the password
Go to AOL sign-in page>> login your AOL email on iphone>> Go to AOL setting>> under setting select “change password”>>Type your current password>> Then create new password>>Click continue>> Then save.
Incase AOL email is still not working then make sure you have the most recent version of iOS installed on your device.
Pontuação 1
Comentários:
What do I do if someone stole my info and made account with my info dr liscence ssn they stole all my personal info and hacked my Facebook and messenger. Please help me!
por
Since connecting of AOL mail with the iPhone gives alot of problems . These problems are not with the AOL mail but their are some processes which we need to consider while we work on iPhone or macbook.
Lets just cross check with the some steps which we needs to look upon while we Fix AOL Mail Not Working On iPhone
Steps-
1. Turning On and Off of Airplane Mode
2. Resetting with Settings for Network
3. Removing it & adding again
4 Final & last Contacting with the Apple Developer
Thanks
Pontuação 0
For solving the issue of AOL mail not working users need to implement the following troubleshooting steps: Make sure to have a good and active internet connection. Users can also try to reset the Network Setting of the iPhone and then again reconnect with their Wi-Fi using a correct password to see if the error is solved or not.
Regards,
Lewis
Pontuação 0
  • Method 1: Use Airplane Mode to Fix AOL Mail Issue
  • Method 2: Reset Network Settings for a Stronger Impact
  • Method 3: Remove AOL Account from iPhone and Add It Back
  • Method 4: Set Up 2-step Verification of AOL Mail on iPhone
  • Method 5: Contact the Developers Directly
Pontuação 0
Pontuação 0
An Oct 18 email from AOL said third party apps would stop working with AOL mail and listed several options to get iPad, iPhone and other apps working again. My laptop always worked but my iPad and iPhone stopped with an message about a bad password. I used method 3 to generate a “temp” password for my iPad. It involved signing into AOL, going to my account and account security. There was an option then to generate a temporary password. Then I had to go into settings on my device, to mail, to AOL mail to the screen that includes your current password. After backspacing over my old password I typed in the temp password. It “verified” and from that point on my mail began working again. My original password is still the valid password after this setup exercise. I then had to repeat the process for my iPhone. Hopes this helps.
Pontuação 0
You probably need to delete the AOL account and add it again. Be sure you choose the “AOL” type of account when adding. Some people have AOL set up as an IMAP account— that won’t work.
Depending on the version of iOS you’re on, you may need to create an “app-specific password,” used just for the Mail app on your iPhone. Your “real” AOL password remains the same as it was but you will have a special one for the purpose of making Mail and AOL work together.
Pontuação 0
Adicionar a sua resposta
Keith será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 51
Últimos 30 dias: 100
Duração total: 15,786
