Ir para o conteúdo principal
No picture, no sound, no blinking lights on Sony KDL-40W600B
Cannot turn on with remote or button on TV. Unplugged power brick, waited overnight. Applied power again. Got a brief Sony logo on screen, then it went dark. I have repeated the power disconnect/reconnect several times. Results always the same. No picture (other than the Sony splash screen), no sound and no blinking lights of any kind. I notice that after the splash screen the display has a very dark purple-ish tint until I remove power. Is this a bad board? Any help with which one, if that is the problem? Thanks in advance!
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta Mais Útil
@jazzbo "this “after the splash screen the display has a very dark purple-ish tint “ is most likely your backlight being on. This could very well be a mainboard issue. Post some pictures of your boards with your question so we can see what you see. Adicionar imagens a uma pergunta já existente
Make sure you have a multimeter so we can check a few things
Esta resposta foi útil?
Pontuação 3
1 dos comentários:
oldturkey03, thanks for the fast response. I’ve added pictures of the 3 boards.
por
Hi @jazzbo ,
Since you get the splash screen and the unit stays powered on, I'm wondering if it is a software problem rather than a hardware problem. Which would also be on the mainboard where the problem may be as suggested by @oldturkey03
Here's a link showing how to update the firmware in your model TV.
I don't know if it will work if your TV's firmware is a later version or not.
You can contemplate attempting this as a last resort if all else fails to resolve the problem
Pontuação 2
1 dos comentários:
Thanks @jayeff. If all else fails I'll give this a go.
por
It sounds like you have a faulty LD BOARD. Replace it you are good to go. just for emphasis it is the second picture you uploaded.
Pontuação 0
Adicionar a sua resposta
R Foster será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 578
