Can this wire be replaced?
we were replacing the Antenna Flex Cable w/ iFixit kit. The snap end of this wire broke off. Is there a way to replace this wire, or fix it so that it snaps back in place? Thank you.
Esta é uma boa pergunta?
The cable comes soldered to a replacement charging port. Order another one of these and you will be fine.
Esta resposta foi útil?
Good Afternoon,
I would say you need to order another cable. You could try to solder the connector back to the ribbon if you have the ability to micro-solder. Otherwise I would go ahead and order a replacement and give it another go.
Cheers!!
Monte
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 35
