Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Manuais de reparo abrangendo todos os tablets da Apple. Os reparos podem exigir aquecimento e cuidado no procedimento de abertura.
5472 Perguntas Visualizar todos
Charging issues on Ipad devices
lately we have been getting in iPad air’s and iPad Pro’s with charging issues we start with replacing the charging port then if that doesn’t work we try the battery and then the charging IC but we have noticed that none of these are fixing it. Has anyone else had similar issues and if you have were you able to find a fix?
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
The Essential Toolkit
The most helpful tools in our most compact kit.
Comprar agora
Comprar agora
1 Resposta
Solução escolhida
I can’t speak for the Pro but on the iPad Air, the problem is usually with the charge port or the battery. By charging IC, I presume you are referring to the Tristar IC. However, I have not seen much success when changing that IC. When the problem persists, it is usually the PMIC. However, they are a more challenging repair and the replacement cost of a PMIC can be quite high so not all customers agree to the repair for such an old device.
Esta resposta foi útil?
Pontuação 3
Comentários:
What is the charge for this PMIC repair ? I am having a similar problem.
por
Adicionar a sua resposta
Jonathan Pegues será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 44
