Ir para o conteúdo principal
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
420 Perguntas Visualizar todos
Why does my laptop only last 2-3 minutes without a power adapter?
MacBook Air (13-inch, 2017)
Processor 1.8 GHz Intel Core i5
Memory 8 GB 1600 MHz DDR3
Graphics intel HD Graphics 6000 1536 MB
It’s been shutting down unexpectedly. At first, it was every 1 hour or so, than minutes, so on and so forth.
I’ve tried an SMC reboot, NVRAM, reinstalling macos. I did a hardware check (holding d on the keyboard when powering on). They said it could be the power adapter so i changed it, only for it to say that no issues were detected.
Battery condition, it says normal and with a cycle count of 731.
What could be the issue? Could the battery be faulty regardless of what the mac says?
Thanks.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Did the battery replacement solve the problem?
por
Adicionar um comentário
1 resposta
Solução escolhida
Yep, it's a bad battery here. Here is parts and guide on how to replace battery. Guide is the same for 2013-2017 13” airs.
Substituição da bateria do MacBook Air 13" de início de 2015
MacBook Air 13" (Late 2010-2017) Battery
Imagem de MacBook Air 13" (Late 2010-2017) Battery
Produto
$69.99
Esta resposta foi útil?
Pontuação 4
1 comentário:
Thank you! I'll get a new battery as soon as i can.
por
Adicionar a sua resposta
Thomas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 350
