Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Um console de videogame para TV produzido pela Sony Computer Entertainment; o PlayStation 4 Slim (CUH-2000 Series) é o modelo sucessor do PS4 original. Data de anúncio: 7 de setembro de 2016.
308 Perguntas Visualizar todos
Can I swap parts
I have a ps4 slim with a bad motherboard and a ps4 slim with a bad blurray drive..can I swap motherboard or blurray from one to the other if they are the same model ?
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
The Essential Toolkit
The most helpful tools in our most compact kit.
Comprar agora
Comprar agora
1 Resposta
Solução escolhida
The drive itself is synced to the motherboard. Personally I would try to replace the drive from the bad motherboard and put it into the good motherboard ps4 slim because if it in fact works it will be the easiest option. If this doesn’t work then you will have to swap the internals of the ps4 slim drive make sure you mark them so you don’t get confused. below is a greta teardown.
https://www.sosav.com/guides/game-consol...
Esta resposta foi útil?
Pontuação 0
Comentários:
Ok but what if I buy a replacement drive will this sync with motherboard?
por
if you buy a replacement drive you will have to follow the last part of that guide to swap the internals. you have to keep the old framing of the disk drive so you can put the new internals into that.
por
My slim is not updating error su 421198-6 error..I was told it's a Blu Ray issue will a new drive fix this or new lens
por
for that i'm not really sure I can't find that error anywhere. https://www.playstation.com/en-gb/get-he...
playstation has a pretty good site to lookup error codes
por
Adicionar a sua resposta
Rosnelle williams será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 30
Duração total: 351
