Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Perguntas Visualizar todos
Pergunta encerrada
Force restore will not work; iTunes does not "see" phone
Following the directions on iFixit I can get my 1st Gen iPhone to display the connect to iTunes graphic, but when I connect it to my Mac iTunes does not "see" the iPhone, so I can't restore it. I tried two different USB ports and two different USB cables to be sure the issue wasn't the connection (and anyway both ports and cables work fine with my iPad).
Suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Have you tried plugging it into a wall? Does it charge? If it doesn't your dock connector may be bad. If that is not the case I wouldn't know.
Hope it helps!
Esta resposta foi útil?
Pontuação 0
2 comentários:
It charges fine.
por
Actually, having said that it doesn't appear to be charging consistently.. loose connection? Is that something I can replace, or is it on the logic board?
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 895
