deep discharge cmos reset
Hallo everryone, few days ago I pry damaged F11 and C257 and C23 capacitors. And when i was reinstalling, and when it turned on all setting even date and time were reset.
also battery discharges very deep and even shows 0V when checked. Battery is newly installed fron istore.
my Iphone doesnot accept original charging cables ether.
Can you please suggest me where to look up for problem.
Update (06/01/2019)
Actually authentication problem occurred at first when I accidentally connected an usb hand fan to my phone.
now the phone is charging very slow and discharging very fast.
I used normal soldering 40W gun to solder. I checked for grounding but it was fine.
will it might be problem of Trisar IC?
Esta é uma boa pergunta?
1 comentário
Change your question to include relevant details and not waste time. You killed tristar by plugging in a tristar killing fan. Then you misdiagnosed that to be bad battery and botched the battery replacement knocking off a row of small components. Now you want to know why it has rapid drain.
por jessabethany
