Black screen after display fell out of case
So what happened was the display fell out while in use. I guess it wasn’t secured by the previous repair guy. What happened after it all got plugged back in was no power and no chime. I took a look at 2 connectors had been torn slightly, but enough the cable didn’t sit all the way in.
So I started with replacing the logic board because I don’t have experience soldering board components. I then got a chime and the computer to start. However it was stuck with a black screen.
I also plugged it into an external monitor. The main screen showed up, but it acted as if it was a secondary monitor so all I could see was the background and top navigation.
I then tried to replace the LED back-light inverter board. Replaced it, turned it on and same issue.
Then I tried replacing the display cable (because it looks like it’s the only cable you can swap out) and still same issue.
I’m avoiding having to replace the entire display, but it looks to me like it I might have to as something else might have been damaged I don’t see. I’m not against replacing it, but the screen didn’t fall very fall, just enough to pull the cables out of the connectors. So it didn’t seem like it might have done damage. If anyone has any advice on what I should try next I would appreciate it. Thanks.
Edit: Here's a picture of the bottom. The screen falling out is not the issue right now. I have replacement screws to keep the screen in place once I fix it.
My issue is that I get a black screen when I boot it up. I hear the startup chime just fine and am external monitor works. Not the screen falling out.
Esta é uma boa pergunta?
Are you sure you have the correct model listed here? The 2011 model uses magnets on the cover glass and the LCD panel is screwed to the chassis!
The 2012 'Thin' Series uses adhesive tapes which secures the unitized cover glass LCD panel into one part. A common issue is failure to clean the surfaces completely and properly prepping the surfaces (leaving oily residue) or worse yet! Thinking the old tape is still sticky enough and tries to use them! Which it is not.
por Dan
Look on the bottom of the stand for information on your model. If you plug the serial number in here to tell exactly what it is
https://everymac.com/ultimate-mac-lookup...
por mayer
OK you do have a 2011 27" !!
Your systems specs: 27" iMac i7 3.4 GHz 3.4 (Mid-2011)
por Dan
I know that I have a 27" iMac from mid 2011. I need assistance with the black screen I'm getting when I power it on. I get the startup chime and an external monitor will work. I can't figure out what's broke that it shows a black screen.
por Repair-IT
I'm just shocked someone would forget the screws!
Even if they had put in one or two things would have been so much better! Clearly this person is not skilled and should be reported to your better business bureau.
por Dan
Exibir mais 1 comentário
