Ir para o conteúdo principal
Second generation of the Ford Focus.
95 Perguntas Visualizar todos
Pergunta encerrada
How to replace the rear hub assembly
I need to replace the rear hub assembly on my Saleen Focus. Not sure if it needs to be pressed on or if I need a puller to get it off. Want to find out before I get in over my head and get the vehicle all apart.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
chase mintrone. I got some instructions about the removal of the hub, the spindle and the wheel knuckle from a service manual They are available for you on here Hope this helps and let me know if this information was what you needed. Good Luck
Esta resposta foi útil?
Pontuação 1
1 comentário:
@oldturkey03 - I know this is a pretty old post, but any chance there is a new link? I am trying to find out how (and how difficult it would be) to remove and replace my rear spindle.
I just created a post regarding replacing my spindle.
Thank you in advance!
por
You want to do it by yourself. I back you up. Go for it!
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,080
