crank and rod bearings torque sequences
on a v6 1993What is the crank and rod bearings torque sequences
Esta é uma boa pergunta?
@gudstuff this is where it gets interesting:
Tighten
11.1. Tighten the crankshaft bearing cap bolts on the first pass to 20 N•m (15 lb ft).
11.2. Tighten the crankshaft bearing cap bolts on the final pass an additional 73 degrees using the J 36660.
Install the connecting rod caps, bearings and nuts.
Tighten
7.1. Tighten the nuts evenly on the first pass to 27 N•m (20 lb ft).
7.2. Use the J 36660 in order to tighten the nuts on the final pass an additional 70 degrees.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 342
1 comentário
@gudstuff what displacement is this engine? 4.3?
por oldturkey03
