Ir para o conteúdo principal
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
903 Perguntas Visualizar todos
Where can I get a ribbon lock for the screen ribbon?
I busted the little black plastic ribbon lock that keeps the screen ribbon in place whilst trying to re-attach it. Is there a good source where I might be able to get more?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I think you're talking about one of these (the black part): https://d3nevzfk7ii3be.cloudfront.net/ig...
If that is indeed what you're talking about, it's not a separate part. It's part of the socket that the ribbon cable fits into. Best case scenario is you only broke the black plastic piece and the rest of the socket is intact, in which case you can try to find the same socket elsewhere, pull the black plastic piece off, and push it into place on your iPod. If the socket itself is damaged, however, the proper repair is to replace the whole socket.
Otherwise, look for ways to rig a fix. Put some kapton tape on one side of the cable to provide pressure, slide/press it into place, then some more tape to hold it in place and hope it doesn't come loose.
Polyimide Tape
Imagem de Polyimide Tape
Produto
Polyimide Tape
$9.99
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks! That's the part, except it's the one on the logic board itself. Are you talking about Kapton tape?
por
Nevermind! I just saw the link to the tape
por
Adicionar a sua resposta
Steven Clark será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 78
