Can I add discrete graphics to Mid 2014 MacBook Pro
Hi I have a retina macbook Mid 2014 with intel Iris graphics and wondered if I could add discrete graphics to it as an upgrade?
Esta pergunta é pertinente?
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
Reputação: 11
There’s no way to do that.
Comentários:
This series came in two different configurations:
The logic boards are physically different! You can't add the GPU chip. You can only swap out the logic board which would be expensive!
por Dan
Thanks Dan - that answers my question
por Jeffers De Maio
If it was the 2016 or newer model with Thunderbolt 3 ports, I would have advised you to research the possibility of using an eGPU. I don't believe this is available for the model you have.
Comentários:
There are a few eGPU systems which work via Thunderbolt-2. At this point it would be a used unit.
por Dan
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 151
