MBP Mid 2015 Battery Replacment - No Battery Power
I just replaced the battery on my MacBook Pro 15'' Retina Display Mid 2015 following these instructions:
Substituição da bateria do MacBook Pro 15" com tela Retina de meados de 2015
....with this kit:
MacBook Pro 15" Retina (Mid 2015) Battery
I had to replace the battery as the lid was not closing all the way, and the lower case feet (on the front-end trackpad side) would not touch the flat surface of a desk/table. Upon removing the lower case, the battery cells looks like inflated airbags (swollen).
Trackpad and keyboard are all ok and functioning after replacing the old battery with the new battery.
However, the problem I'm running into is the laptop will not stay powered on without the MagSafe power adapter / charger.
I've reset the SMC as outlined in step 74 above as indicated:
https://support.apple.com/en-gb/HT201295
....as well as reset NVRAM / PRAM:
https://support.apple.com/en-us/HT204063
....both on multiple occasions. I'd like to get to the point to calibrate the battery, however even after leaving MagSafe charger connected for ~12 hrs (constant amber), laptop doesn't run off of battery and powers off as soon as MagSafe charger connection is removed (which is constant state amber). The battery “charge” level stays at 18% and never changes. I am not able to get into my user profile and install coconut battery as the laptop immediately reboots after entering my profile password. Same with temporary guest account - laptop reboots.
I don’t have any peripherals or external monitors connected - just MagSafe charger only.
I removed the lower case and re-checked all connections, which are all intact, as well as removed the battery connector from it's socket connection to the logic board and re-connected the battery connector before attempting another SMC reset / NVRAM re-set, etc, but am still getting the same result with rebooting.
I see a reference in this post (Mid 2012) with someone else experiencing same symptoms from @danj that references a likely issue with a charging logic issue:
MacBook Pro won't turn on after battery replacement
Could it be a bad (new) battery or could it be a logic board issue that didn't exist until I replaced the battery?
Esta é uma boa pergunta?
