Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
615 Perguntas Visualizar todos
Screen change keyboard don't show up
Okay, here is the weird situation.
I changed the screen of an iphone 8, everything works perfect, customer came back, he cannot edit or add contacts because the keyboard wont show, but on everything else keyboard pops up.
Anyone know what this is?
I suspect a software issue since keyboard is showing every where else.
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
Try a hard reset first (See: Comment forcer le redémarrage de l'iPhone 8)
However I think you are correct, a software fault is the most likely cause of this and that would be fixed via an update/restore.
Is the customer on the beta program? A friend of mine is and he could only answer incoming calls, his dialer wouldn’t work until the following update was available.
Esta resposta foi útil?
Pontuação 1
Comentários:
Actually thanks for this, but it was me having a mayor brainfart.
I just had to double click the homebutton and exit all programs.
por
No worries, if only all fixes were that easy!
por
Adicionar a sua resposta
nicolay.94 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 43
