Ir para o conteúdo principal
How mant times can you replace a iPhone screen before connector wear?
How mant times can i replace te screen of a iPhone before the connectors break or are weared out
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Usually this kind of connector is rated 10-50 cycles, with 25 being the most common rated cycle counts.
But that only means the connector is no longer compliant in some way, actually it still works good enough well beyond that if you handle it with care.
Esta resposta foi útil?
Pontuação 3
It depends on how gentle and precise is the hand doing the job, Some people manage to mess the connector with just one replacement by deforming the plastic part to force push it in place. If things are done properly I’d say tens of times, the 6S has pretty a solid connector.
Pontuação 2
Adicionar a sua resposta
Lester crewe-jones será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 59
