Ir para o conteúdo principal
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
200 Perguntas Visualizar todos
There are Dark shadows on my LED TV screen
My samsung LED tv has dark shadows which appear all the time . any help will be appreciated
Esta é uma boa pergunta?
Pontuação 2
3 comentários
I also have this problem, Samsung don't want to know. They just say take it to my local service centre who are quoting £500.
por
@dean.barb925 did you want more info on this or are you okay with what Samsung told you? If so post a new question https://www.ifixit.com/Answers/Ask and add a couple of good pictures to your Question so we can see what your screen displays. Adicionar imagens a uma pergunta já existente
por
I have this problem, un58j5190 dark spots replaced power supply and worked fine replace power supply again this year still have dark spots pics are in the answer section by accident
por
Adicionar um comentário
3 respostas
Pergunta mais útil
bakhtiyar.badar  that will depend on what these dark spots look like. It is possible that this is a bad backlight array, LED covers that have come off or a bad signal etc.. Remove the TV from power by unplugging the TV. Remove all video inputs. Hold down the power button for 30-60 seconds. After that connect the power to an outlet and use one local video source(i.e. DVD/BR player) and try to turn your TV on. Let us know what you get. You can always post some images of what your TV shows with your question. That way we can see what you see. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 1
more than likely the LCD panel is going bad. I came across one tv the a ribbon cable wasn't in all the way but there was a dark part of the tv about inches going top to bottom. Pinch the bezel a few times around where the dark spots are on the top or bottom. if they move then you have a loose connection..if they don't move and they are getting bigger it's a bad panel.
Pontuação 0
1 comentário:
If thats the case a loose connections how to fix it...thank u
por
I did a factory reset. That got rid of my shadows on my Samsung tv . It shouldn’t be happening on a 1 year old tv!
Pontuação 0
1 comentário:
How did you reset.
por
Adicionar a sua resposta
bakhtiyar.badar será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 121
Últimos 30 dias: 510
Duração total: 58,941
