Why will my tablet not power on?
I have a Lenovo 58 but after using thistle a few months one day it just went off and never came back on since then could anybody help me to fix this issue thank you
Esta é uma boa pergunta?
Good day, this issue is common in smartphones and tablets and could be caused by both minor and major issues. first i advise that you charge your device, if it still does not power on while on charge…you should then try a different charger and let it sit on charge for a while, if none of the above works it may be a problem with your battery , charging port or the IC Unit. i advise you to bring your device to a nearby repair shop to get it checked out and revisit this site when the problem is identified
-MCI TECH
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 91
