from which side of the machine is right and left; top or bottom?
I have a MacBook Pro Late 2008 - Mid 2009 2.4 GHz
One of the fans is making noise like a muffled roulette wheel. I have had problems that led me to believe I needed a logic board replacement. So I tried replacing the logic board. But, the solution was to reset the PRAM (see note below).
I had the logic board in and out of the machine some six times. So I have plenty of experience with taking out and putting the fans in. I don’t know which one would be right and left. Is right and left from the top of the machine or underneith the machine?
Note: I had a display problem originally: Horizontal white stripes and rapid oscillation of the whole display up and down. I was told I needed a new logic board. In the ensuing “adventure” a forum response suggested I reset the PRAM. It fixed the original board even thought I did it while I had a replacement board in the machine.
Esta é uma boa pergunta?
1 comentário
Your systems specs: MacBook Pro 15" 2.4 GHz Core 2 Duo (Unibody)
por Dan
