Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1695 Perguntas Visualizar todos
After Fan Repair, Discs are No Longer Recognised
I followed the guide to replace the fan on here. I managed this, PS4 turns on, works fine, plays digital games. Then I tried to insert a game disc to play but every time I tried to load the game, it would say the disc wasn’t inserted. My optical drive did have a bracket on top which I didn’t remove at any point in the repair. Is it the wrong way round or could a loose cable be the culprit? Where you insert the disc did feel very high up but as a new PS4 owner I don’t know if this is significant. Any help would be greatly appreciated. Thank you very much! Let me know if you need any more detail!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Does the disk drive spin up? If it does, but refuses to read, you probably didn’t attach the cable correctly. Try going back in a make sure it’s in well, those cables can be stubborn.
Esta resposta foi útil?
Pontuação 0
2 comentários:
It does spin up yes, I’ll go and have a look at the cables and see if that helps, thanks.
por
Okay so I’ve opened it back up and it did seem the ribbon cable was loose and one of the ears folded over. I have currently got it held in place with blu tack until I can find something better
por
Adicionar a sua resposta
Charis Smith será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 45
