Ir para o conteúdo principal
Fourth generation of the Toyota Pickup.
49 Perguntas Visualizar todos
I've been having trouble with my truck it won't crank to start
I can push start it and everything else is fine but when I turn the key to start it’s like everything on the dash goes out for a second then comes back. I replaced the ignition switch yesterday but it did nothing to fix the problem. How hard would it be to install a push button for the starter?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Have you tried to jumper 12 volts to the small terminal on the starter solenoid to see if the starter switch in the column lock may be worn out and causing the problem? If that is the case, then yes wiring a aftermarket simple button to start the vehicle would be a trivial fix for you.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
alan.thomas65 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 177
