Cut electrical wire cord for A1243
I need to know how to replace the cable or repair it.
Esta é uma boa pergunta?
If it is an USB cable that was cut then you should open your keyboard and re-solder a new cable to the PCB. Please mind to properly connect polarity of the USB power supply and Data cables. It will be 4 wires + ground so if you are handy with soldering iron then you should handle with it.
Esta resposta foi útil?
then finish your %#*@ teardown and fix it while your doing it
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 1,187
