Ir para o conteúdo principal
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
iMac tripping breaker just by plugging it to electricity!
iMac 21” (EMC: 2638)
The iMac was connected to a UPS but through an extension cable, so not directly.
So the iMac was running as usual when suddenly it went off, with all the other devices that are connected to the UPS. And I have no electricity in the room, the electricity breaker tripped, and the UPS is making that loud beep.
After unplugging everything from UPS, and turning back electricity and etc... I found out that it was caused by the iMac.
(UPS and all other devices are working fine now without the iMac there).
I try to plug the iMac to a different socket, but it immediately trips the breaker even before clicking the power button, just by plugging the cable to the socket, trips breaker!!
I tried different sockets in different rooms that are connected to a different electricity breaker, but the same thing happen.
I tried a different cable, but same thing happen.
I unplugged cable from the back of the iMac and tried the 10-sec hold power button thing, but didn’t help, same thing happened.
TL;DR - iMac is tripping breaker just by plugging it to electricity, without even pushing the power button!!!
Any one has any idea what happened here??
the closest Apple service center is hours far from me and I would really want to try everything before going there.
Thank you!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Did replacing the psu work? I seem to have the same problem. My iMac causes a power outage.
por
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Here’s a link to the iMac Intel 21.5" EMC 2638 Power Supply Replacement guide.
Check the power supply for any obvious problems such as burnt out components etc and also if you have a DMM (digital multimeter) use its’ Ohmmeter function to test between the incoming active power connectors and between the connectors and earth.
Do all of this with the power totally disconnected from the computer.
If there is a short circuit in the power supply and you cannot find its’ location ifixit sells replacement power supplies for your model. (I think that this is the correct one - if you decide to buy one from them verify with them that it is the correct one).
Imagem de Replace a burned out power supply compatible with a Late 2012 to 2019 21.5" Intel iMac.
Produto
iMac Intel 21.5" (Late 2012-2019) Power Supply
$129.99
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you very much.
por
You have a short circuit causing the breaker to trip. Have it checked by a qualified technician. Parts may have come loose inside creating the short circuit.
Pontuação 0
Adicionar a sua resposta
WhatisThat será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 43
Ao todo: 4,897
