Looking for new panel for LG
Had a cracked screen for my lg 3D tv . Looking for new panel for LG 65UF8500-UB model. Any recommendations where to find the replacement part.
Esta é uma boa pergunta?
Sudhakar Parchuri it will be very difficult to find a panel and even if you do, it will most likely cost you more than a new TV. To search for a replacement you will need the number from the back of the panel, not from the TV. Remove the back from your TV and check the label on the panel. Use that model number and try a search. See what it will find. At best, you can try and find the same model TV ( which hopefully has the same panel) that is broken other than the panel. Use that one to harvest the panel for your TV. None of this will be simple or quick.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 153
