Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1656 Perguntas Visualizar todos
MacBook Pro 13 inch a1278 very slow
HELLO EVERY ONE
my laptop very slow modell MacBook Pro (13-inch, Mid 2012)
can i get help
thnaks
Esta pergunta é pertinente?
Pontuação 0
Comentários:
i try to change hdd and cable sata seam
por
Does it do this in Safe Mode?
por
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
These simple steps provided below won't take much time, but will greatly help to improve your Mac's performance.
1. Find resource-hungry processes
If you see that some app is using a lot of CPU power, you can close it from here by choosing the app with the mouse and clicking the X in the left-hand corner of the Activity Monitor.
2. Manage your startup items
A clean startup helps speed up slow Mac.
3. Turn off visual effects
4. Delete browser add-ons
5. Reindex Spotlight
If you recently updated your OS, you would be aware of the slowness that occurs when Spotlight is indexing.
6. Reduce Desktop clutter
Every desktop icon takes up RAM space. Fewer icons — the faster your Mac gets.
7. Empty the caches
8. Uninstall unused apps
9. Clean up Mac’s hard drive
10. Update your Mac
11. Free up RAM using Terminal
12. Replace your HDD with SSD
13. Add more RAM
If you do these activities regularly, you won't have to worry about the need to speed up your Mac again. There are also some other methods which can help speed up your Mac.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
abdulkafi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 2,161
