Pular para o conteúdo principal
1.6, 1.8, or 2 GHz G5 processor
163 Perguntas Ver todas
Can you have both bluetooth and airport card in computer
if both card are installed will one
interfere with the other?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
Comprar agora
iPhone X Fix Kits
Comprar agora
1 Solução
Solução escolhida
Apple has a couple of knowledge base articles that deal with the subject:
http://support.apple.com/kb/HT1365
http://support.apple.com/kb/TS1809
The second article specifically says that in the Macbook Air, using multiple Bluetooth devices can reduce the transfer rate of Airport networks. One of their suggestions is to use the 5 GHz 802.11 network instead of the 2.4 GHz network (an option I believe is only possible with the 802.11n Airport machines).
The first article mentions the possibility of Bluetooth/Airport interference without specifying computer models. But it offers the same kind of advice -- such as using the 5 GHz channel and reducing the number of active Bluetooth devices.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Sparky será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 1,549
