Why is the dryer giving a call service code?
call service comes up and dryer stops 4 to 5 minutes after starting. If I restart it once or twice it will finish the load. any idea whats wrong?
Esta é uma boa pergunta?
Cause 1
Heating Element
The heating element warms the air before it enters the dryer drum. Over time, the heating element can burn out, causing the dryer not to heat. To determine if the heating element has burned out, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Parts
Heating Element for your Kenmore Dryer
RepairClinic Item #1482984
Dryer heating element assembly. 5500 Watt 3 coil element with housing. If the dryer does not heat check for a blown themal fuse or thermal cut out. Heating elements will often have a break in the coil element if defective.
$74.80
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 37
Duração total: 2,658
2 comentários
Does it give you any error codes? What is the make and model number?
por mayer
tore it apart and found the heating coil is broken but touching and still heating. is the problem from the coil or did it go because of a bad thermal cutoff or high limit thermostat. no error code...just call service. model 417.81102000 kenmore elite assembled in 2011...steam and soft heat technology. I'm guessing the high limit thermostat is ok and was the reason the dryer shut off and brought up the "call service"
por tlfore
