Pular para o conteúdo principal
XBox One Schematics diagrams
I need help identifying 2 resistor values near the HDMI ports. Any help would be greatly appreciated. Thanks in advance for your help.
Update (04/08/2019)
Here are some pictures
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Comentários:
Not sure those uploaded or not
por
I attempted to post some pictures for you. I don't think it worked. Anyways, I hope my description was helpful.
por
Don't see them. can you upload them to imgurl or tiny upload and post link? I got the board in front of me there is quite a few resistors there
por
I will see if I can post a new question with pictures.
It just says Image. I don't think it's going to let me.
por
I posted a new question tilted "need help identifying 2 resistor values" you my need to scroll down to see the pictures.
por
Mostrar mais 2 comentários
Adicionar um comentário
2 Soluções
Solução escolhida
I just took measurements from a board I'm working on, the resistors read 2K (2,000) ohms on my meter. Hope this helps, size might be 01005.
Esta resposta foi útil?
Pontuação 0
Comentários:
Thank you very much for your help and time.
por
You are welcome.
por
Can I ask you why you are looking for these two resistor values? What’s the issue with your Xbox?
can you provide a picture of which ones exactly I could probably get you the values since my Xbox one is torn open currently.. as I’m trying to fix a turning on issue.
Pontuação 0
Comentários:
When trying to get the HDMI jack out, I heated the board up to do so. Whish I had a pre-heater and a nice hot air soldering machine. Hence why I should of waited till I got back to work where I have these tools available. I'm out from surgery though. Anyways, to make a long story short these 2 resistors fell off the board. The resistors are labeled R1M2 (bottom of board near HDMI out jack) and the other is R8A4 ( I believe this one was green in color on top side of PCB near HDMI in, close to the pins of the port) I was swapping out the HDMI in for the out. Real pain in the butt without the proper tools. I really appreciate your help so much. Thank you
por
Adicionar a sua resposta
chris wilcox será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 71
Últimos 30 dias: 257
Todo: 937
