Why does my yahama amp keep blowing fuse?
Hello. Guys, I have a yamaha dsp a590, fuse keeps.blowing. Fuse is 3.15a. Located by the voltage switcher. Please assist.
Esta pergunta é pertinente?
Double check the voltage selector and see what it is set at. If it is okay then your amp may have a short circuit somewhere in the power line of the main board. You will have to disassemble it and see if you can visually identify components that look damaged or missing. Post some good images of your board as well as the location of the fuse etc. with your question. Adding images to an existing question
You can download the service manual for this amp on here
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 770
