Ir para o conteúdo principal
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
382 Perguntas Visualizar todos
Why is my PS4 Pro crashing my wifi
I am connected via ethernet to a tri-band router. When I try to play a game, the wifi crashes but the game continues. But everything connected to wifi are unable to connect. If I change to a wifi connection, it still will crash the wifi. Anyone else have a similar problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Everyone has a different definition of what it means to “crash the wifi” … but my suspicion is that your game is hogging all or most of your Internet bandwidth thereby either denying anyone else access to the Internet, or slowing them down so much so, that it’s too painful for them to use the web.
IT COULD also be a problem with your router, although 99 times out of 100 if a router is going to deny people access to a network, it will deny everyone universally and not allow just one machine and not the others, unless its been configured to give your PS4 priority traffic.
Here is what I suggest you do (in this order):
1) Unplug your router (so it turns off) and wait 2 full minutes then plug it back in and see if the problem still happens. If i does then…
2) Reset your router to FACTORY DEFAULTS - the manufacturer should have instructions on their web site showing you how to do this. See if problem still exists.
3) Borrow a router from a friend - a known good working router and try it. If it works, then replace your router with a new one.
4) If the behavior was the same with a friends router, then call your service provider and get faster Internet.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Perhaps I was not clear on my issue. The PS4 is connected via ethernet. When I turn it on and try to play any game, the wifi completely shuts down for everyone. But I can continue to play the game using the ethernet connection.
por
I think Mike is right. If I have to guess, I think most routers prioritize ethernet connected devices before wifi connected ones, so essentially when you launch the game, it uses all the available bandwidth leaving nothing for everyone else.
por
Adicionar a sua resposta
James Thomas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 2,796
