Ir para o conteúdo principal
Released November 2018 as an edition to the iPad's Pro line. Model A1980.
62 Perguntas Visualizar todos
So can we not buy JUST the digitizer?
I’ve searched the internet and I can’t find the digitizer by itself to purchase.  I cracked my glass but the actual screen below is fine, I just need the glass digitizer but I can’t find it anywhere.  Do they not sell it anywhere by itself?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thy are all over eBay.
Good luck
por
Adicionar um comentário
1 resposta
Solução escolhida
Digitizer and LCD screen are bonded by OCA on iPad Pro 11, even if you manage to buy the digitizer by itself - you won’t be able to use it as you need special equipment to separate glass from LCD, remove adhesive residue, and install bought digitizer onto the screen with new OCA adhesive.
It will save you a LOT OF time and trouble to buy the LCD/digitizer assembly to replace that broken glass.
Esta resposta foi útil?
Pontuação 5
Adicionar a sua resposta
tphelps será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,183
