What is the size of the 11 screws at the base?
I need to know the size of the 11 screws for the back cover so i can order replacement
Esta é uma boa pergunta?
Hi,
According to the service manual (p.32, Removal of base cover) the 11 screws are M2 × 3.5 mm, Phillips-head, nylok-coated.
Good hardware stores should have M2 x 3.5mm screws, maybe not nylok coated though
You could also search online using the part number for the screw pack (5S10K38946) for the Ideapad, but you may get other different screws as well as the 11 screws that you want.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 844
