Ir para o conteúdo principal
Battery percentage suddenly drops from ~60% to 7%
A few weeks ago, I decided to replace my macbook’s battery - after 5ish years, the only thing about this laptop (the best laptop ever made) was the battery life drained quickly. I ordered a battery + kit from iFixit, and replaced the battery. I conditioned the battery, but every time it discharged it would jump from above 50% battery to 7% battery, then die shortly after (i.e. a very discontinuous discharge). I received a replacement battery for the replace from iFixit, and replaced again. However, I’m still having the same problem with the battery jumps . I figure it’s unlikely to be the battery, but am unsure what else could could be causing the issue. I’ve reset PRAM and SMC.
Esta pergunta é pertinente?
Pontuação 22
Comentários:
It seems ifixit knowingly sold a lot of bad batteries. Replacing a mid 2014 MBP battery is a 50+ step operation to get the battery in, and then the same number of steps to put the unit back together again. The only way to know if you got a bad battery is to install it.
Take Apple up on its $199 OEM replacement, because odds are ifixit will send you another bad battery.
por
I have the same problem. Did you contacted Ifixit? Or did you fix the problem already?
por
Hello, the same situation here!
por
The problem is still there… my battery dropped from around 60% directly to 7%… maybe this is one of the consequences from relying on China… they produce defective products and we have to suffer.
por
Hello, Jacob, did you find out about the problem? I have exactly the same issue now. Brand new battery (second already) and battery level drops from around 60% to 7%, remaining for quite some tome on the 7% level after that.
Cheers, cal
por
Mostrar mais 1 comentário
Adicionar um comentário
28 respostas
Solução escolhida
Download Coconut Battery on your Mac and add some screenshots to your question, thus we may be able to see some additional technical figures. However that seems to me another faulty battery, there seem to be quite a bit in the market with such percentage jumps issue and hibernation not working at all.
Esta resposta foi útil?
Pontuação 5
Comentários:
Added a screenshot of activity monitor and coconut battery
por
@tumblingpenguin As I feared, another faulty battery, capacity is not coherent with 3 charging cycles and behaviour confirms its bad performance. Just ask for a replacement.
por
I am on battery number 4 from 3 different vendors. Ebay and Amazon. This sucks
por
Pergunta Mais Útil
Same problem for me. Replaced battery in my Macbook Pro Retina 2015 with an iFixit battery.
Followed all the steps they recommend including resetting the SMC card.
Charge drops abruptly from 90% to 6%.
Went through whole recalibrate procedure several times. Never any difference.
And huge hassle to swap out the battery on this machine, having to remove the whole logic board to do it.
Can’t believe iFixit is shipping defective product after defective product. Wow!
Pontuação 7
Comentários:
Tbh, I don't think you need to remove the whole logic board to replace the battery. I only unplugged a couple of connectors and used dental floss to disattach the old battery. Google it.
por
don't have to remove the logic board in retina battery replacements. its fairly easy even without having to take the board out..
por
ya iFixit fighting for right to repair and always complain what issues apple products have and how hard it is to repair and then they ship defective garbage them self.
por
I’d be interested to know how many people are returning these, and if anyone has gotten one that works. Based on the comments here, it seems like all of the batteries iFixit is shipping recently are bad. Would be nice to know if this is the case, as it would save a lot of people a lot of time replacing faulty batteries with more faulty batteries..
Pontuação 6
Comentários:
I don't think this is specific to 'iFixit' batteries, I've tried 5 different batteries from 4 different suppliers now (not iFixit), and had similar problems on all but the last one. I think there's just been a lot of really poor quality batteries coming out of China since late 2018, and those that are problematic are only starting to show up recently. Unfortunately we're all still at the mercy of the Chinese (and Apple of course, but that's another story).
por
Wish I'd seen all these comments before I ordered from iFixit and went through a super complicated battery replacement process (Macbook Pro Retina 2015 requires removing almost all the internals to change the battery). Mine new battery from iFixit is defective in just the same way that everyone else is reporting here. Maybe time for some sort of class action lawsuit against iFixit?
por
Hello,
Did find any solution?
i'm running on the same issue
por
Replaced mine 2 weeks ago, same exact issue.
Pontuação 5
I am in the same situation with a MacBook Pro (Retina, 15-inch, Mid 2015). Im on my 4th battery and they have all had the same exact issue. Like everyone here has mentioned iFixit’s customer service has been great the whole way. Sadly looks like I’ll have to return this last battery and hope I can get one that works from another vendor.
Pontuação 3
Comentários:
Just an update. I bought another battery from another source and swapped the 4th iFixit battery out for the new one. New battery works as expected! 5th battery is a charm! iFixit customer service was great during the entire process but they are certainly shipping dud batteries. I would suggest anyone with this issue should buy from another vendor.
por
I thought I was imagining what I was seeing as mine does exactly this.
Looks like I need to RMA it.
por
Eric, would you mind me asking which vendor you purchased the working battery from? I'm having the same issue with my iFixit batteries, and I'd really love to get one that works ASAP, as pulling it apart and having duds is not very pleasant.
por
@mp_fix I got the battery from macsales (OWC). Works like a charm after ~3 weeks of use.
por
Just wanted to follow up and let others know that I also replaced this battery with an OWC battery, and it is working well, no issues since I replaced the battery over a week ago.
por
I’m having the exact same issue. They are sending me battery #3 for me to Try on my mid 2015 15” mbp. If it doesn’t work I’ll be requesting a refund and buying a battery else where. IFixit support has been stellar though!
Pontuação 2
Comentários:
So the third battery performs better than the first two, but it still has issues. Total capacity has dropped about 5% after just two charges. iFixit is giving me a refund and I'm going to try a battery from macsales
por
Same problem here (drop from 70% to 7%) after following these instructions: https://help.ifixit.com/article/265-batt...
I also did the SMC reset.
I am getting about 3hrs of battery life with just the activity monitor and with the screen on (66% of brightness)
I did have a similar problem two years ago with another ifixit battery I bought for a MBP 2011 13”, I sent it back and bought a Newer Tech battery that also reports an inaccurate percentage. I am really frustrated with this after spending 80€ on a battery that is supposed to be of high quality.
Pontuação 2
Comentários:
I have received a replacement and this one seems to be working as expected. I am getting 6h (bright 70%) light use (web browsing + mail + bluetooth mouse and keyboard).
por
Where did you buy it plz?
por
I’m having a similar issue, but I don’t think it’s the battery. At least not the battery cells. I recently replaced my battery using an IFIXIT battery. I starting seeing the problem you’re describing, rapid drop in displayed battery charge, with my old battery. The Apple diagnostics indicated my old battery was ready for replacement, so I assumed the battery charge was actually dropping that quickly due to a failing battery. However, I’ve seen that happen with my new battery as well.
Here’s an example of how my new battery is performing. I was running off battery only and the displayed charge went from 100% to 72% in what appeared to be a normal rate of discharge. I had been using my MacBook Pro in a typical way; emails, web searches, image viewing, etc. To go from a displayed charge of 100% to 72%, it took ~ 1 hr 50 mins. At that time, the display jumped to 7%. My plan was to continue using the laptop until the battery fully discharged. I continued working for another ~ 40 mins and the displayed charge stayed at 7%.
I had to move on to something else, but left the laptop on. The display sleep was set to 7 mins and the computer sleep to 15 mins. I would wake it up every 15 to 30 mins, navigate a bit and then let it sit. The displayed charged stayed at 7%. I actively used the laptop for ~ 2 hrs 30 mins and then the sleep/wake up cycling for another ~ 1 hr to 1 hr 30 mins. The battery completely discharged sometime between the 1 hr and 1 hr 30 mins mark. I didn’t witness it.
So, I think that’s fairly normal battery performance, ~ 3 hrs 30 mins to 4 hrs running off battery only power. Therefore, I think the battery cells are performing fine. That leaves the battery charge sensing circuitry. I’m not sure if that function is performed on the logic board or the small circuit board on the battery assembly. I’m planning on getting a new logic board for another problem, so I’ll see if it also fixes the battery charge state display. I think the graphics card that’s built onto the logic board is having issues, as I’ve been having a problem with the screen randomly blacking out, while the computer stays running.
I tried to get a logic board from IFIXIT and a couple of other sources, but they were all out of stock. When I get a new one, I’ll post the results. If the battery charge sensing function resides on the battery assembly circuit board, then a logic board swap won’t solve the problem.
If anyone out there knows where the charge sensing function is performed, that information would be helpful.
Pontuação 2
the censers that control the % of battery may be shot or they may not be wired up correctly
Pontuação 1
I am having the same exact issue… I requested a replacement of the battery, which arrived today. I installed it and… same issue again. Unsure if it has to do with the compatibility or what. The last battery was also loosing it’s capacity very quickly, so we’ll see what this one does.
Not entirely sure how to solve the issue, and if the laptop requires the full disassemble in order to change the battery (i admit i only replaced the battery without disassembling other parts).
fingers crossed but hope is low.
Pontuação 1
Comentários:
i got another battery from them and the issue is still there. Not sure what the issue can be but aside from “a faulty battery”, being the second one from iFixit that I install, i wonder if this is just the nature of it. any idea?
por
iFixit brought in a bunch of defective batteries and put them "out there" anyway. After three hours replacing the battery, I have to repeat the process just to get the defective one back to them. And they KNOW they're bad!
por
I bought a different brand some time ago and i have now the same issue again. calibrated and reset multiple time. few days ago I got the "service battery" sign. Apple (italy) charges 209 Euros to replace the battery but I also have the new 16 inches mac and honestly spending 200$ on an "old" computer (altho perfectly functioning, battery aside) is a total bummer. We all know by now the issues with the batteries so... is there any way to solve this? are we all getting this wrong or is there no solution whatsoever? maybe i'll just tape the charger to the laptop and i'll call it a desktop machine....
por
I have the exact same issue on my Macbook Pro Late 2013, and this is the second battery I’ve received from iFixit. What I’ve notice isn’t just the sudden drop in charge from about 50% to 7% but also the reverse when charging, as it will jump from about 65% to 100%.
Update (12/09/2020)
Has anyone else experienced these sudden drops in battery charge from iFixit batteries bought lately? If so, what is the brand of the battery maker? My current original Apple battery is from DynaPack (labeled as DP), which can be easily seen with CoconutBattery but also under Apple’s System Report in macOS. I’ve contacted the iFixit help desk and they guarantee their batteries with a two year warranty. One of their suppliers is Simplo, which I believe supplies Apple with OEM batteries as well. My feeling is that whatever batteries don’t pass Apple’s quality assurance tests get knocked down to lower quality replacements, among which these iFixit batteries which have these sudden drops. However I have some faith in iFixit products since they are willing to stand by their products with a two year warranty. Any thoughts?
Pontuação 1
Comentários:
Do you still have the same issue? I just replaced my battery and I'm having the same problem.
por
I have exactly the same issue. I tried fully draining it and recharging a couple of times, but nothing helps. CoconutBattery says the battery is in fine state, but decharging abruptly goes from ~90% to 7% and shutdown within an hour. Recharging suddenly jumps from ~40% to 100% after an hour or two.
por
Mine was broken. I had to replace it with one that works.
por
I'm still using the original battery which seems to be holding up, at least for now. Both iFixit batteries were defective.
por
I didn't get my battery replacement from iFixit but my new battery manufacturer is Simplo, and I'm experiencing the same issue. You may be onto something...
por
So, it sucks to say this on the iFixit forum but… I got a battery off Amazon and it seems to be working fine. Got 3 hrs of editing on it and it went just fine. No sudden drops etc. Havent tested internet browsing etc but all seems regular. Will report back in a bit with more testing. All in all I can say that it was not a motherboard issue, it wasn’t related to any repair mishaps or else. Simply a bad battery (well.. two fo them).
Now, I don’t think it is an iFixit issue and their customer service is stellar. I think that given the age of the machine, some of the batteries may be “dated”. Maybe the Late 2013 machine is just old and the batteries that are around now were meant to be purchased long ago… don’t know.
But again, the new battery works fine. I won’t post the link out of respect for ifixit but a quick search on amazon (i got mine from amazon italy) will show a range of batteries around 50 Euros. I got the one with the best reviews…
good luck everybody. BTW the Late 2013 MBP is still a solid machine, I have done all kinds of video editing and color etc and i works great. yes, slower than my new top specs MBP 2019 but hey…6 years old and still competing…
Long live the Late 2013 mbp (with a new battery)
Pontuação 1
Comentários:
Could you recommend please the vendor of the amazon battery? Because I'm in the same boat and iFixit is not able to offer me another replacement (I already used 3 of their batteries in a month and a half, all of them with the same problem).
Amazing customer service, but sadly these batteries (as I understood it's a common problem during these months) are not so well functioning.
por
Ifixit WILL NOT stand behind defective batteries unless you spend another 4-6 hours swapping in a new one. NOT. WORTH. IT. See posts here (Battery percentage suddenly drops from ~60% to 7%) on frustrated customer’s multiple attempts and class-action lawsuits.
por
Did you have the right tools already, or did they come with the battery from Amazon?
por
I am on my 3rd battery as well from Ifixit. I’m almost to the point of just sending this to apple to get it fixed. :|
Pontuação 1
Comentários:
I installed battery #2 without using the adhesive as I wasn't very hopeful it'd work in my machine. It also erroneously reports charge state. time to cut my losses and get a refund I think.
por
I ended up with a newertech battery from OWC, and it's now working perfectly fine.
por
por
OWC one has been running fine since Nov. Apple wanted $750 cause they would replace the whole top case :|
por
I am having the same issue with a late 2013 MBP and my second iFixit battery. The first just straight up died after about a week. This one jumps from 30-50% charge to 7%, then sits there for a while, then dies. Like everyone else, I have had very good customer service from iFixit, but not pleased with the quality of the product.
Pontuação 1
Comentários:
I tried to get iFixit staff to engage about this continuing issue reported here on the forum. They refused and instead kept pointing me at their 4.8 star rating on their own page (who knows how they curate those ratings). Have now replaced with a Newertech batter purchased from Macsales.com. It works correctly, and their install video is better than iFixit's install photos.
por
Same issue here, I took my computer to a store ( not Apple ) to get the battery replaced ( and I guess they probably got the new battery from iFixit ). Noticed this issue and immediately thought he installed some knock-off battery. I took the computer again, picked it up and I was told there were no issue anymore and that they re-replaced the battery. Still the same problem, what should I do? Honestly I don’t think they’re gonna fix it. They’ll probably find some excuse. I’m thinking of taking it to Apple Store and ask for a refund. Any advice? I waisted 2 weeks over this thing already.
Pontuação 1
Comentários:
Thank you, I brought back my MacBook to the same store ( I have 3 months warranty ) they’re trying with other batteries from different suppliers, hopefully one of them works. If not, they said it may be the motherboard (???) and that would not be fixable. Wow, I never heard of this! Will Apple store still fix it even though I took it in a non-Apple store already?
por
@Luna If you take it to an Apple store or send it in as is, I believe they will fix it once it's logged in and received. Mine went in with iFixit's bad battery. I had no choice. I had already disposed of the one I took out. Ifixit was like too bad, no refund.
por
Same same here. Installed an iFixit battery into my MBP 15 Late 2013 and got the percentage drop issue from ~60% to 7% where it will stay for a while before shutting off. Of course I did recalibration and SMC reset.
I could work with this as the overall performance is ~4h which seems normal to me. But unfortunately the MBP slows down under 10% to save energy and that really sucks when using the MBP for productive things.
Claimed an exchange battery which I received very quickly but exactly same issue. Seems to me that the iFixit batteries are not very reliable.
Pontuação 1
Comentários:
After reading your and other posts i asked for a refund. Otherwise this will take a lot of time.
por
I did as well and quickly received the refund from iFixit. Ordered a new battery from NewerTech which was working like charm at once.
por
I’m not convinced it’s a battery issue. I’m on my second new battery, reset SMC, calibrated on both and same thing - suddenly goes from like 70% down to 7%. Activity Monitor shows Google Helper using a lot of CPU resources so I’m wondering if it’s a software issue.
Pontuação 1
Comentários:
Don't know for sure but I can tell you that - after my second iFixit battery - a different replacement battery from NewerTech fixed the issue quickly for me.
por
Just throwing my hat in the ring, I’m having the same problem but not actually going to blame iFixit in this case - more on that in a sec.
Both a friend and I have/had Mid 2014 15-inch MBPs that we bought at the same time. Maybe about half a year ago he decided to swap out his battery with an iFixit replacement and had the exact same issue: battery went from about 60% to 7% instantly and coconutBattery showed his battery health to be in the low 80s after just a few months. This was on a battery he got as a replacement because his first battery (also from iFixit) was doing the same thing. He ended up just selling his MBP back to Apple as credit for a new one (I guess they didn’t run any diagnostics or didn’t care because they did accept it, though he only got a couple hundred bucks).
Fast-forward to now and I just got a replacement battery from iFixit and of course am experiencing the exact same issue, except mine drops to 7% when I hit around 35% battery. After just four charge cycles my battery health dropped from 100% to 96%. Just to be clear - I made sure to calibrate the battery exactly how iFixit recommends, and I did all the usual stuff like reset SMC/PRAM, etc that never actually seems to work (but did it any way).
Furthermore, I have never used a 3rd party charger, I did buy a second charger to keep in my office a couple years ago, but I bought it directly from Apple. I’ve also absolutely babied this machine, I’ve never dropped it and it still looks brand new to this day. The only issue that shows up when I run a diagnostic is that it says the battery needs service (despite being a new battery) though it says that it’s still safe to use the machine.
I’m not the tinfoil hat type, but I’m going to wear one in this instance. We are WAY beyond coincidence here. Two batteries from a friend, one from me, all having the same exact problem. Users here have reported replacing their battery as many as SIX times. This is also not just a “bad batch” because this issue really started happening about two years ago from what I can tell (heck this very thread is now two years old) and bad batches don’t last for two years.
I’m really starting to wonder if Apple themselves are up to something. It’s just weird that all of this started really happening at around the same time and it’s still happening to this day. Apple is fighting hard against right to repair, something that iFixit is very much for (and is largely the face of the whole movement). I absolutely wouldn’t put it past Apple at this point to pull something shady because the more people see that iFixit batteries constantly fail the more they’ll think “well, Apple is right - third party replacements STINK!”
I’ve never had any issue with any other iFixit battery and I’ve replaced batteries on multiple Kindles and such. They’ve always exceeded expectations. Of course different batteries will come from different sources, but it’s hard for me to believe that iFixit, who has a great reputation otherwise, would not have addressed this issue by now.
Other people have reported luck with OWC batteries so I just ordered one from there and we’ll see how that goes. I super promise I’ll update this thread with my findings (I set a reminder so I don’t forget, I know people always say they will update threads and never do - I will).
Pontuação 1
Comentários:
There are some things you can/should fix yourself and can be successful.
With iFixit’s Apple laptop replacement batteries, the pleasure is not worth the pain. The one I replaced had to re-glued back in (a 3-hour procedure, which they want you reverse, so you can send them back the battery to make sure it really IS defective; they know it’s defective!). Too many horror stories here.
Bite the bullet, pay Apple to do it. iFixit does not stand behind the defective batteries they sell, and they are OK with the number of customers who buy-pay-install / remove-ship back… and for many, rinse and repeat!
por
UPDATE (as promised)
I was willing to give iFixit a pass in my previous message but after having installed an OWC battery I have to say that there is probably an issue with iFixit batteries because this OWC battery is FAR better. This is crazy because iFixit batteries have been having this problem for two years now. Based on the fact that I’ve personally seen two iFixit batteries exhibit this problem and some users are reporting as many as six failed batteries in a row, well, that doesn’t fare so well for iFixit.
Other users have reported that OWC batteries are better and my experience aligns with that 100% I’m getting almost double the battery performance with OWC and am not having any weird issues where charge suddenly drops. Also with the iFixit battery when I ran macOS diagnostics it would detect an error with the battery but say that it was still safe to use (error code PPT004), I am getting no errors with the OWC battery.
Furthermore, the OWC battery was cheaper and came with basically the same tools.
If you’re having problems with iFixit batteries then give OWC a try, or better yet, see if Apple will resolve the problem (OEM is usually better).
One thing I did notice is that the manufacture date on the OWC battery is 2015 and iFixit was 2021. I’m not sure if the old manufacture date will present a problem (maybe it’s an error? I’m using coconutBattery to see the manufacture date), but at this point in time it feels like a brand new computer (2014 15-inch MBP).
Pontuação 1
The chances are, you simply need a new battery. You can get one (I hope you know your serial number) from https://support.apple.com/13inch-macbook... in order to purchase one directly from Apple.
Pontuação 0
Comentários:
Apple isn't at all keen to fiddle with units that have non-OEM batteries in them - I had to re-install the old Apple battery to even get the genius bar to talk to me.
This thread reminded me I hadn't left a review of my failed experience with the product. I have difficultly believing this is a 5 star product and I somehow randomly got 2 bad units...be sure you leave a review.
por
Thanks Matthew. That will be helpful for the person that I suggested to. Can you think of any other websites to get Mac parts? If you can, I suggest posting it as an answer.
por
WAIT!.. STOP.
iFixit has had a slew of defective batteries that they will require you take out and return (after gluing them in). Search on: "Battery percentage suddenly drops" here on this site. This process is 50 steps to get the new battery in, and another 50 to put all the parts back. For $199, Apple will do the whole repair, warranty it, and also replace the trackpad and the keyboard (because it's easier for THEM to do).
por
The simple solution to this defective battery, in that case, is to simply not buy one from IFixit.
por
It is sad that the whole discussion here is about bad batteries. It can be totally something else but people do not know it and advise accordingly. Let me reformulate the question. This drop occurs with definitely GOOD battery. What causes it and how to fix it? Does someone know? Thank you.
Pontuação 0
Comentários:
I think if you read the entire thread (and all the comments) you'll see that many people have had success with batteries from a different vendor. The evidence suggests it IS a problem with bad batteries. When people get a working battery from another vendor, the problem disappears.
por
I regret I changed my battery. Even my original 5 years MacBook book battery is much better than this new battery from $@$* china.
por
I think all of the batteries probably come from the same vendor in China. iFixit totally punted on any refund without getting their bad battery back (3+ hours). The problem is if you bring a batteryless MacBook to Apple, they won’t accept it.
Shame on iFixit. They know they sent out bad batteries for an extremely difficult repair. Disappointed.
por
I wish I’d read this before buying my battery . Same issue here, did the install, did the battery charge + 2 hours then ran it flat ( didn’t watch the % just ran Netflix on it until it died) Then fully charged it. Twice now the battery had dropped from 70 % to 7% instantly. Not checked as above if the 7% is erroneous as that is not an issue I’d be happy to live with. Just sent my screen grabs to ifixit and will await their response. The thought of doing the swap out again does not fill me with joy. I think if they acknowledge the fault I’ll ask for a refund and put my old Mac battery back in and send it off to the experts to do ! Frustrating to say the least !
Pontuação 0
Comentários:
This sounds like you had a deeper issue than just needing a new battery. Did you check to see if your charger was working properly and was a real Apple unit.
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
You also expected the battery to be charged in two hours. The paperwork with the battery tells you to charge the battery for a good 12 hours. And then you need to calibrate it.
por
Same problem here, I wish never bought the iFixit battery, I love their tools but parts are cheaper than Aliexpress ones at Apple prices. From 70 % to 7% instantly.
Never recommend buying mac batteries from iFixit.
Pontuação 0
Comentários:
You know even they get a bad batch once and awhile. How about giving them a call to get your battery replaced under the one year warranty they offer. Sitting on your hands and complaining is a bit weak on your part!
por
The battery is defective. ifFixit will exchange it for another (that may or may not work). The time and labor to remove and re-install is your problem. That's their policy.
por
@mfmauceri - They sell the part you are the one putting it in! Why would they pay for someone to replace your battery? They didn't charge you the labor to put it in the first place. Yes! It's a pain, Apple glued in the battery making it hard to replace, And of course thats iFixit's fault?? No! They do stand by their batteries. But you only have one year, So five years out you want a new battery?? Nope!
por
@Dan They sell bad batteries. Period. And they know they're bad. Mine didn't take 5 years to crap out, it took 5 days. By then I had sold the laptop touting "New Battery." I paid to have it fixed because I have a sense of honor.
iFixit wouldn't reimburse me the cost of the battery without getting the original back. Apple disposed of it. They won't repair laptops with missing batteries that were once glued it. Dope!
Is there iFixit suck-up merit badge your trying to earn?
por
@mfmauceri - So you go to a store and buy some Romaine lettuce, you get deathly ill but of course its the stores fault! Nope! The grower of the lettuce messed up and how many stores got the bad lettuce?? Here in the states over five states in New England got the tainted stuff so all of those thousand or so stores are bad stores too! Nope!
Get real here! I know its a pain, iFixit got a bad run of batteries it happens! They do a QC sampling. Some issues can still pass through their efforts (and a few sellers got stung by this supplier)
So if you made the effort to contact them I know they would take care of you! How do I know as I've gotten a few bad batteries over the years and they always took care of me and I've helped quite a few folks here all of them got a replacement and they are all happy campers!
Instead of grousing, how about picking up the phone or email them and get a replacement battery (assuming you haven't waited too long)
Contact iFixit Customer Support
BTW - I have no interest in iFixit. I freely volunteer my efforts here answering peoples questions.
And I do beat up companies that do wrong to their customers. I don't beat up stores who got stung by a company selling bad product! I've called out quite a few over the years.
por
Mostrar mais 2 comentários
Same problem here. Wish I read this article first…
Its now march 2021 and ifixit does not fix this problem?
Pontuação 0
Comentários:
por
You may have a very different problem! Are you sure the charger is good and is a real Apple unit? Did you check the MagSafe connections?
por
No, i don't have a different problem. The macbook is 100% fine. After 9 sycles the battery health drops down to 83% and the battery still drops down from 60 to 7%. Reset SMC multiple times. After i checked the battery, 1 cell was blown up already also.
por
How is this still a thing? Just installed mine and exactly the same thing - gets about mid-way through discharge (60-50%) and then mysteriously drops to 6%! What do I do now?
Just out of interest, what OS are people running? From Mojave to Catalina, my battery age went from 6 months to ‘unknown’ - something funky going on there?
Pontuação 0
Comentários:
You remove the battery; may be easy, may be glued-in. You send it back to iFixit, and hope they don’t send you another defective one!.. then you rinse and repeat, and some clown on this forum will tell you it’s normal.
por
I have recently had the same issue my battery went from 92% to completely drained in an instant, I had to reconnect the charger just to to get my MacBook Pro to switch on.
Does anyone know why this is happening
Thanks
Pontuação 0
Comentários:
Because your battery is f*cked.
por
What Jereon said.
por
ooohhh ok looked like its going back....
thanks
por
Just replaced my 2012 Macbook Pro battery. It’s dropping from 70% to 20% in under a minute. Seems to be charging back up but I can see a pattern here. Contacted support.
Off topic - don’t always rely on reviews and star ratings. I worked for a company that wrote a script that hijacked the review before it were submitted if the review was under 4 stars. Not saying ifixit is doing that, but it’s entirely possible to “fix” stars and reviews.
Pontuação 0
Hi,
just bought a new battery for my old macbook pro 2010. First time I change the battery because lately I had the same issues : battery percetange drops, and moreover, overheating….
So I plugged the new battery yesterday. Was 67% , then I used it unplugged first… It suddenly drops to this 7% whereas it was around 40% just before it happened. Then I did plug it and let it charge the whole night. Now today, was 100% first. After a while did drop to 97%, which in my experience, could happen. So no worry here. But then now, it drops to 81% with no reason. Macbook tells me that battery is not in charge and power source is : sector. So… Pretty weird. I want to add : It is not an ifix battery.
I live in Chile. Just bought a supposedly official apple SMP battery. I will update in the new few days.
It is kind of weird. I just want to add my feeling : I am really skeptical about battery problem, and could be a software problem from Apple… Remember battery management from Iphone and their mismanagement of it. So I don’t know. My macbook pro is 11 years old, so…. maybe it is hardware related. But reading all those comments, I am really skeptical, even if some people say it worked better with some other new battery. Or as someone say : third party batteries just suck.
Pontuação 0
Adicionar a sua resposta
jacob sager será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 22
Últimos 7 dias: 180
Últimos 30 dias: 760
Duração total: 21,892
