Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
465 Perguntas Visualizar todos
Swap logic board Late 2013 with Mid-2014?
I have a Late-2013 (MacBookPro 11,2/2.0GHz/8GB) MacBookPro that works fine, but I also have a Mid-2014 (MacBookPro 11,3/2.8GHz/16GB) which boots and works, but has a failed battery, cracked screen, and messed up keyboard. Since they both are Retina 15” MBP Model A1398, can I simply swap the logic boards? Do I need to swap the i/o boards too, or anything else? Or worse, is there something I don’t recognize as being different that I should be concerned with?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It appears that your 2013 is an integrated graphics and the 2014 is a dual graphics. The boards are not listed as interchangeable.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks, but follow up: Where are you looking up the interchangeable feature? Also, what about the GPU (or lack thereof) make the boards non-interchangeable? Is the display different?
por
Adicionar a sua resposta
crimson_egret será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 213
