Ir para o conteúdo principal
The Fitbit Alta smart wearable by Fitbit was released in 2016. It features a tap-activated display screen that is slightly smaller and thinner than comparable models.
20 Perguntas Visualizar todos
It won't pair with my phone.
Hi, is there a service center here in Philippines? I can’t pair my alta. Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try to reset your FitBit Alta, uninstall the App from your phone and start as fresh.
Steps for restarting FitBit is as follows :
  1. Plug your charging cable into a USB port on your computer or any USB power adapter.
  2. Insert the other end of the cable into the port on the back of your Fitbit Alta. Your Alta will begin charging.
  3. Press the button on your charging cable three times within eight seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into your computer.
  4. Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
  5. After you see the logo you can unplug your tracker from the charging cable.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Hygelle Banez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 129
