Ir para o conteúdo principal
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150 Perguntas Visualizar todos
Ipad won't connect to home wifi
All Apple devices will not link up to home wifi. Changed password wifi and still no connect. Rebooted system and reset Apple products network system and no connect. Advices wifi password is wrong. All other android devices connected no problem.
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
"No connect" is too vague; more details and information is needed. Are you getting an error message? Is it not seeing the network? You say "All Apple devices" but specifically call out just an iPad 6; is it just a single iPad or are there other devices that can't connect? Can they connect to other wifi networks?
por
Adicionar um comentário
2 respostas
Hi,
  1. Go to settings (app)
  2. Then select “General”
  3. Scroll down and click on “Reset”
  4. Now click on “Reset Network Settings”
  5. Go back to “WiFi”
  6. Select your WiFi
  7. Re-enter password
Esta resposta foi útil?
Pontuação 0
common problem check ur wifi conection with another apple device if conects then safe mode ur ipad and delete the most recent app u installed or update it and then boot up as normal also reset ur wifi
Pontuação -1
Adicionar a sua resposta
roroeow7 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 437
