My iPhone 7 dropped rear camera stopped woking
my iPhone 7 dropped rear camera and flash light stopped working & also GPU benchmark showing zero and while edit old photos like increasing brightness image goes black
kindly what is exact issue happens with GPU or any other issue
i tried replace with U2501 CAMERA IC but still rear camera not working front camera working fine
Esta é uma boa pergunta?
The problem is in the logic board… and by the looks of it it requires board-level repair. I suggest to change the logic board. But I’m not sure.
por Kon Dev
Kon, Thank you for your continued contributions to the Answers Forum. However please stop "guessing" and contradicting yourself within your own answers. The point of this forum is for folks to help each other with shared knowledge and expertise.
If you don't know the answer, then it is best to simply not answer. Otherwise wrong or false (even if not intentioned) information can cause more harm than good. Any information you share should be based on your own experience or be based on research which you would share via a link.
The moderators thank you!
@mayer @oldturkey03 @jayeff
por Minho
