Slowing down and hanging
Is it possible to upgrade the computer with better processor and motherboard?
Esta é uma boa pergunta?
Yes, but you would need to replace the motherboard. The CPU is together with the motherboard so you can only upgrade from the same year usually from an i5 to an i7 usually.
Esta resposta foi útil?
And where could I buy those motherboards?
While I agree with @benjamen50 on upgrading the CPU would require a swap out of the logic board.
Depending on your exact system you might have other cheaper options. As an example upgrading the RAM or even the HDD/SSD drive.
Memory 8 Gb 1067 MHz DDR3
HDD Samsung 500 Gb SSD
You've already maxed out the RAM to 8 GB. Your drive maybe on the small side if you have it more than 2/3rds full.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 45
2 comentários
What is your exact model? Reference this listing EveryMac - All MacBook Pro's Tell us which one.
por Dan
MacBook Pro (13", mid 2009)
Processor 2,26 GHz Intel Core 2 Duo
Grafic NVIDIA GeForce 9400M 256 Mb
por Mats Kallmyr
