My flash isn’t working
The problem is, my rear camera isn’t working but I don’t know why the flash won’t work I don’t know if it has something to do with the rear camera
Esta é uma boa pergunta?
The rear camera and flash are apart of the same item, if one fails it’s often that the other one will also, you might have to replace them or you can try a reboot and see if that helps.
Esta resposta foi útil?
The rear camera is a separate piece from the flashlight but a bad rear camera will cause flashlight to not work in most cases.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 29
