Ir para o conteúdo principal
The Olympus OM-D E M10 Mark II is a 16 megapixel mirrorless camera that was introduced in 2015. This camera can interchange lenses with its easy to use platform that is both user friendly and priced for amateur photographers without lacking professional capabilities.
4 Perguntas Visualizar todos
Dispaly cable Olympus OM-D E-M10 Mark II
The tilt display works in some positions, but in most - not.
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
Me too. I will to try replace flex cable. Any suggestion for it?
por
Same problem here. Any alternatives to sending it in for repair?
por
Adicionar um comentário
2 respostas
If the problem is a damaged cable, which it may or may not be, you can get a replacement off eBay easily: https://www.ebay.com/itm/New-LCD-Flex-Ca...?
Esta resposta foi útil?
Pontuação 0
I found this video showing half of the cable replacement works. Does not appear to be easy:
https://www.youtube.com/watch?v=8wpLLklS...
Is is also not clear from the video if he ever managed to fix his camera.
Pontuação 0
Adicionar a sua resposta
valeri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 25
Duração total: 1,303
