Keyboard problem MacBook Pro 13" 2012
Hello anyone,
I have a keyboard problem on my Macbook pro 13" 2012 with macOS Mojave 10.14.3 .
So example when i try to type 5 I get 5è, or if I try to press the right arrow I get 8, or if I try to press the up arrow I get 9”.
Does anyone know if is a software problem or there is a way to reset keyboard's drivers.
Thanks.
Update (03/11/2019)
Hello and thank you all,
I think it's a hardware problem, I did a test in a virtual machine with a linux distribution and I had the same problem, then I connected an external apple keyboard and it works without problem.
Also with the keyboard viewer I had no problems.
Advice on where to buy a keyboard to replace it?
Update (03/21/2019)
Hi everyone,
I solved my problem by replacing the keyboard with a new one.
Thanks to everyone for the support.
Esta é uma boa pergunta?
1 comentário
i had the same problem. but only the key 5 , p , g . i found out when i press (option + 5 )key it shows the right character ,so i thougth was a hardware problem, so i try with a external keyboard and it was working perfectly , so after to many tests . i make the deccicion to just replace the keyboard but befor order the parts i did my last try, i have an other macbook pro 15' mid 2012 i just switch the ssds and start it to work again like normal . no problems so i just cloned and installed the ssd in my macbbook and now it works p-erfectly.
i hope it work for somebady whit the same issue.
por Leo Inciarte
