Ir para o conteúdo principal
A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
79 Perguntas Visualizar todos
The washer does not fill. Water goes onto the floor and none in the wa
The washer does not fill, and water goes onto the floor and none in the washer. It does not leak when it is not trying to fill.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
gary.curry1955  pull the washer aways from the wall and check the supply hoses as well as the water inlet valve supply. Sounds like your water inlet supply is leaking since all the water for the washer comes from there. for more detailed help we would need to know your exact model number. Check this video for an idea about the valve
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
gary.curry1955 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 80
