I have installed a new black ink cartage, not printing, color is fine
HP OfficeJet Pro 6960 is not printing in black ink
Esta é uma boa pergunta?
If you see an “0x6100004a” error, your printer must be serviced. Otherwise, you may have a bad cartridge.
Esta resposta foi útil?
If it’s been a while since something was printed, it could very well be that the head is clogged. I had that problem with my printer recently. You can probably find a tutorial online on how to clean it with some acetone.
Try setting print options to gray scale and print a test job. If you still do not see anything then you may have a defective ink cartridge or the print head needs to be cleaned or replaced.
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 686
