How do I update the firmware on this camera. I can't find the download
If you know where to get it pleas leave the link and details with how to find it there. Cheers!
Esta é uma boa pergunta?
Your best bet - is NOT TO
these cheap cams generally do not get updated.
Even when they do, is variant dependant, NOT accumulative.
V1, V2, V3 are not progressions but different hardware suppliers, so they are not updates, but separate firmware that's NOT interchangeable.
I don't know specifically about this cam, but this is a clone of the Eken H9 I think, (probably OEM from Eken) and with that cam there's over 25 variants of the same basic cam
All not interchangeable
Also the Akaso EK7000
has fake 4k
Fake pic resolution for anything over 4mp
Esta resposta foi útil?
usually the firmware download is “zipped” - so you have to uncompress the file,
this should be sphost.brn
copy that to the root directory of a blank sd card of at least 8gb
that said . ….. updating these types of cams - Is a bad idea
MOSTLY the updates are not improvements, they are for compatibility reasons, different hardware components are used, (- hense the “New firmware”) and likely differs from the hardware in “Your” cam, and you will “brick it” (won’t work)
Últimas 24 horas: 8
Últimos 7 dias: 25
Últimos 30 dias: 96
Duração total: 5,875
Hi @sky_in_general
I've found only V1 firmware by AKASO, but there are no others links, try to write on the technical support for a newest firmware. It would be the best way to get latest update.
por Lucas
where is that? on the website of akaso?
por [deleted]
Yep, https://www.akaso.net/firmwares
por Lucas
ok, could you explain the exact download process? Because I see varying techniques on the internet. I just formatted the sd card then drag and dropped the file onto the card and put it into the camera. When I booted up the camera. It never came up with any firmware update icon and I still have the same issue of freezing after I start recording and then losing the recording after about 1 minute.
por [deleted]
I think, you must use their APP called Ismart DV APP - Because they recommend software updates via Ismart. I don't know, if there is any other way to a successful update.
por Lucas
Exibir mais 2 comentários
